Posted by CNKS on November 12, 2014 at 17:39:14 from (216.144.104.128):
In Reply to: Re: 53 sa engine posted by gene bender on November 12, 2014 at 14:42:12:
To get good readings the engine apparently needs a water pump. For my 53 Super A I put a sender in a SC upper outlet and the temp reads on the edge of the red with a load in just a few minutes. With no load it drops almost immediately. Looks like the temp varies a lot with themosiphon engines.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
