Posted by gene bender on November 12, 2014 at 14:42:12 from (67.55.226.121):
In Reply to: Re: 53 sa engine posted by rray on November 12, 2014 at 12:27:44:
You wont get any readings with the sender placed there unless you can run shutters. You can get good readings with the sending unit located in the upper radiator some housings for SA and SC had such a housing.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
