Posted by rray on November 12, 2014 at 12:27:44 from (108.198.198.73):
In Reply to: 53 sa engine posted by rray on November 12, 2014 at 06:44:25:
Thanks gentlemen, I do want it to run "right" but a full head job for this tractor is overkill. I will clean, check for leakage, and lap if necessary. One thing I would like to add is a temperature gauge. I notice that the lower water intake that bolts to the block has what appears to be a boss on the side. Is trying to drill and tap this a bad idea? I have not seen new ones for sale.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
