Re: engine miss- low compression on my 400
Posted by Bob on December 25, 2014 at 10:29:17 from (64.255.159.192):
In Reply to: engine miss- low compression on my 400 posted by SDE on December 25, 2014 at 09:13:28:
Check that the pushrods are in place and that the valves are correctly set.
Then, do a leakdown test to verify it's leaking past the rings.
If it is, you will simply have to tear into it to see what broke, 'cuz the ones of us out here on the 'net are no better at x-ray vision than you are?
(STILL trying to figure out why you took the piston and sleeve out if it was obvious the head was cracked???)
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? " ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
