Posted by SDE on December 25, 2014 at 09:13:28 from (69.179.23.3):
Initial problem- coolant in oil drop pan coolant on the #3 sleeve remove head and pull piston and sleeve Sleeve and block look good Head has crack in the combustion chamber Tried to weld it myself assembled the engine and it ran good- twice still getting coolant in the oil Warm the engine and add K-Seal to coolant Next 2 times I run the engine it has a miss on #3 Compression, #3 is 75 lbs. add oil, now get 125. K-Seal rep says it can not bind movable parts When I put the sleeve back in, I rotated it a quarter of a turn. I heated the block and cooled the sleeve, but needed to use a block of wood and a hammer to get the sleeve to go in the last two inches. I did not hit it hard to get it in. I did hone it, before putting the piston back in. And it did run good the first two times I ran it. Where or what did I do wrong? I will be tearing it apart soon. If the top ring is broken, is it because there must have an invisible ridge that caused the ring to flex to much? Thank you SDE
Today's Featured Article - Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea
... [Read Article]
Latest Ad:
[More Ads]
