Unless you pressure tested the head after repair its still questionable. If leaking into the combustion chamber it can damage the piston rings or break them on startup if enough fluid gets above the piston. Maybe the first thing to check is after siting overnight, remove spark plugs and see if coolant comes out any of the holes. If not try to move each piston to top and try to see a wet piston top. Depending on pistons that maybe can't be done with the eyeball. You didn't say if coolant was running down inside of sleeve or outside. If outside you probably missed a crack.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
