Re: Engine oil cooler for hydraulic cooler?
Posted by ss55 on August 10, 2017 at 06:19:07 from (63.147.218.40):
In Reply to: Engine oil cooler for hydraulic cooler? posted by Cariboo4x4 on August 09, 2017 at 21:51:46:
Single cylinder engines can vibrate a lot more than most automotive engines and automotive chassis. I would be concerned about that oil cooler cracking and leaking, especially if the cooler is bolted solid instead of on an isolated mounting.
Can you add a temperature gauge to your splitter, or use an infrared thermometer to monitor your oil temperature? In hot weather the people loading and stacking the wood will probably overheat long before the hydraulic oil in the wood splitter. If you can let the people set the pace, you should be fine.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
