If this is a farmall 560 the slower third uses a 32 tooth gear driving a 41 tooth in the transmission. Faster 3rd is a 34 tooth driving a 39. Slow 4th is a 38 tooth driving a 35. Fast 4th is a 40 tooth driving a 33. Would have to figure it up to tell you the speed difference. Played around with those gears in a 400 which turns a lower RPM than a 560 and have some figures wrote down. With a 400 ring and pinion, dirrect T/A, 14.9 tires.at 1450 RPM the slow 3rd goes 4.97 MPH, with faster 3rd 5.56 MPH. slow 4th 6.91 MPH, fast 4th 7.71 MPH. Same as above with a 560 ring and pinion, slow 3rd 4 MPH, fast 4.5, slow fourth 5.57, fast 6.2. Faster first and reverse and slower or heavy tillage 3rd or 4th gears in a 560 are the same gear ratio as the standard ones in SMTA, 400 and 450. May have some numbers confused while typing, if anything looks wrong give a shout.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
