Wardner: 1468 most likely only had 1,000 rpm pto when new. The dual shaft could be installed, however IH frowned on it in any tractor larger than the 1066. I know even my 1066 pto used to run much hotter on max load on the 540 shaft than on a the 1,000 shaft. I soon got rid of my 540 drive forage harvester. I believe somewhere in IH literature they don't recommend exceeding 85 hp demand with 540 pto.
If your putting a dual shaft pto from a 706 in a 1468, it should bolt up and work. Just don't offer him any warrenty.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
